Make your X-Carve stronger, smarter, and more reliable with this update kit. Backwards-compatible with all X-Carve machines shipped before September 2016.
The X-Carve update kit is available in both 500mm and 1000mm sizes.
Each kit contains:
The stepper motor cable is included in case you would like to take advantage of the X-Controller’s extra stepper driver. That part of the update process is a “nice to have” option, not a necessity. If you don’t need to use the extra driver, just ignore the stepper motor cable. More information about rewiring the machine to use all four stepper drivers is available at the X-Controller Usage Instructions under “Option 2.”
NOTE: A 500mm machine cannot be updated to a 1000mm machine without additional parts.
I have a Shapeoko 2 with 100×100 cm and would like to know if this is the correct kit for upgrading it. Thank you in advanced
2 answersThe shopping card shows “Expected to ship by 7/30” for the kit. Is that for real in 2022 or an error? All the components by them self seem to be in stock. Is it possible to get the kit w/o the sideboard for reduced price?
2 answersI have a pre-2016 X-Carve. I am looking at the new update released this year and am looking at upgrading the controller as well from the gshield. Do I just need the two upgrade kits to make this change?
1 answerPutting it into the shopping card, says it’s unavailable for purchase.
When will this be available?
1 answerI am an owner of the original X Carve and would like to upgrade but your store says this is unavailable. Any idea when. the upgrade kits will be back in stock?
