X-Carve Homing Switch Kit
This set of three switches (one for each axis) allow you to home your X-Carve to the same starting point every time. Homing switches are especially helpful if you’re using jigs or carving repetitive project types. The kit comes with enough wire for your X-Carve. No soldering required.
Includes:
• Three (3) homing switches
• Three (3) cable assemblies
• Mounting hardware
PLEASE NOTE
The 2015 X-Carve Drag Chain kit will not work with this upgrade, as the homing switch cable lengths are too short for the number of drag chain links included in the 2015 version. In order to use this homing switch upgrade kit, you will need to upgrade to the latest version of the drag chain kit as well:
- Step 1 (1000mm):: "500mm assembly instructions":http://x-carve-instructions.inventables.com/500mm/step2a/7homeswitch/
- Step 1 (750mm):: "750mm assembly instructions":http://x-carve-instructions.inventables.com/750mm/step2a/7homeswitch/
- Step 1 (500mm):: "1000mm assembly instructions":http://x-carve-instructions.inventables.com/1000mm/step2a/7homeswitch/
- Step 2 (all sizes):: "X-Carriage":http://x-carve-instructions.inventables.com/1000mm/step2b/7homeswitch/
- Step 3 (all sizes):: "Z-Axis":http://x-carve-instructions.inventables.com/1000mm/step2c/10homeswitch/
- Step 4 (all sizes):: "Rails":http://x-carve-instructions.inventables.com/1000mm/step3/
- Step 5 (all sizes):: "Wiring":http://x-carve-instructions.inventables.com/1000mm/step6/ sections.
