Bundle and save with this ultimate X-Carve Upgrade Kit. Increase your X-Carve’s rigidity, torque, and material removal rate—3+ times faster—in just 2 1/2 hours. Reduce chatter and increase accuracy with these rock-solid upgrades to take your X-Carve to the next level!
NOTE: X-Carve Machines purchased 2015 or earlier will need updated X, Y1, Y2, and Z stepper motor cable assemblies.
Includes |
Belt Upgrades |
9mm 3GT belting (3.5 meters) |
9mm belt clips (6) |
9mm belt sleeves (6) |
9mm wide belt idlers (6) |
Stepper Motor Upgrades |
212 oz-in NEMA 23 stepper motors (4) for 50% more torque |
Z-Axis Upgrades |
Direct Drive Z Axis Upgrade |
2” Risers (4) |
Acrylic dust guards (8) |
Installation time |
Around 2 1/2 hours |
Material Removal Rate |
Typically 3x improvement from stock X-Carve |
Installation Instructions |
To get the most out of this upgrade, we highly recommend using the X-Controller Kit and the Wide Makerslide. While the new stepper motors can be run on the original g-shield controller, you will not be getting the full benefit from the upgraded motors.
