Mon - Fri: 9am - 5pm CT
4x2 is in stock and shipping!
You can bet your business on X-CARVE Pro
0% Financing Available
The Total CNC Solution
Plug
Simple Setup
Assembles in less than 2 hours and plugs into any standard 120V outlet
Easel pro
Design Like A Pro
Includes 3-year subscription to easy-to-use Easel Pro software
Drill
Produce More
Crank up production with faster carves and the ability to carve full 4'x8' sheets
Support
US Support Team
We're only a phone call or email away to keep you running
Pick Your Pro
Both X-Carve Pro models have the same best-in-class hardware, software, and support. Choose the size that works for you.
X-Carve Pro 4x4 Bundle
X-Carve Pro 4x4
$11,995.00 $9,995.00
Choose Bundle
X-Carve Pro 4x2
$9,995.00 $8,495.00
Choose Bundle
Brandon
SEE WHAT'S UNDER THE HOOD
Inventables' Community Manager - Brandon Cullum provides an overview of all the exciting features in our X-Carve Pro + Easel Pro CNC solution.
We've got your back
X-Carve Pro is in stock and ships out within 1-2 business days. An included 1-year, limited warranty. US-based customer support. Plus an optional 3-year extended warranty for extended peace-of-mind.
Ships in 1-2 days and includes a 1-year limited warranty.
Drag and Drop Designing
Design like an expert with 3 years of Easel Pro included in your bundle. Prefer to use another software? No problem. Easel Pro imports existing G-Code, SVG, and DXF files.
Two people look at laptop running Easel Pro software
Easel pro
Easel Pro Software
  • 3 years included
  • Drag and drop for easy prototyping
  • Jumpstart new products with a design library of more than 2 million graphics and free projects from other businesses
  • Tiling feature lets you design as big as you need, then tells your X-Carve Pro to carve section by section–seamlessly
  • Cloud-based so we can keep adding the features you want
  • New machine profiles feature lets you use one computer on multiple X-Carve Pro or X-Carve machines
  • Designed specifically for Inventables hardware for seamless use and one-stop customer support
  • Import G-Code and SVGs easily from:
    • Aspire
    • VCarve Pro
    • SolidWorks
    • Adobe Photoshop
    • Adobe InDesign
    • Fusion360
    • Autocad
    • and more...
  • Browser-based, works on Mac or PC computer
Bigger, Faster Jobs
Wall art Cabinetry Board Coffee table Hooks Signs
Carve Big With A Small Footprint
Most of the time, shops don't use the full carvable area of their 4x8' machines, which means a lot of wasted floor space. Easel Pro's new Tiling feature lets you design as big as you need, then tells your X-Carve Pro to carve section by section–seamlessly.
X-Carve Pro carves pieces larger than its carvable area, section by section
Get your X-Carve Pro first
FAQ'S
  • When will my X-Carve Pro arrive?
  • What is the footprint of the X-Carve Pro?
  • I use a different software. Can I import files into Easel?
  • Do I need to rewire my shop for it?
View More
