NEW: Try 3D in Easel Pro. Learn More
Grey MDF Sheet
Strong, organically dyed wood fiber panels - On Sale!
Grey MDF Sheet
$11.11 8 in × 12 in 0.2 in
Features
  • Easy to machine
  • Non-toxic
Cut tolerance
+/- 1/16"
Color
Grey
Thickness
.2"
Type
MDF
Files & Attachments
Data Sheet
Colored MDF Data Sheet.pdf
