Watch the video and see all the building process.
Be aware that I actually used 8mm thick grey MDF and you might only find a thinner thickness on Inventables store so you need to remake the box using the Box Maker App on Easel once you select your bit size, material and material thickness so the box joints come up perfect.
John McWhirter
Megan Palmieri
Mikey Garcia
Dani
