Rev 41 1476
25 opens
2 copies
531 downloads 0 comments
Jon Anderson
Jon Anderson
A REV bracket at 30 degrees out of aluminum
http://www.revrobotics.com/rev-41-1476/
Aluminum Sheet 6061
Aluminum Sheet 6061
Dimensions: 12 in × 12 in x.062 in, Thickness: .062 in
$16.34
Carbide Tip Upcut 2 Flute -  1/4 in Cutting x 1/4 in Shank
Shank Diameter: 1/4 in, Cutting Diameter: 1/8 in, Cutting Length: 1/2 in
$16.34
REV-41-1476.dxf
Secure aluminum to fixture
Use the ‘12×12 Sheet Fixture’:https://www.inventables.com/projects/12×12-sheet-fixture to secure the aluminum using rigid double sided tape or painter’s tape and CA glue strategy.
Note:
REV uses 2mm (about 0.080") aluminum for these brackets.
YMMV depending on your application with 0.062" thick aluminum which is 80% as thick as the 2mm aluminum.
Carve aluminum
Carve the aluminum using the Easel project.
Notes:
– Use lubricant/cooling to extend the life of the bit
– Use a brush or compressed air to remove the chips to improve finish and extend the life of the bit
Release the part
3 minutes
Release the part using a knife, chisel, putty knife or similar. The whole sheet can be removed easily using the screwdriver/prybar release slot on the bottom of the fixture’s cutting area.
Debur
Debur the part as needed.
