Mon - Fri: 9am - 5pm CT
Closed Sunday 8/7
Aluminum Sheet 6061
Lightweight and corrosion-resistant
Aluminum Sheet 6061
$13.43 12 in × 12 in .032 in
$16.34 12 in × 12 in .062 in
$30.40 12 in × 12 in .125 in
$61.43 12 in × 12 in .25 in
$24.57 8 in × 12 in .125 in
6061 is a good, general purpose aluminum alloy with magnesium and silicon as its alloying elements. 6061 has the highest resistance to corrosion of all the heat treated aluminums, but strength is lower. 6061 has a wide range of mechanical properties and is readily machined and has good forming properties. 6061 welds easily, has excellent joining characteristics, and good acceptance to anodizing and other applied coatings. Electrical conductivity is 40% of copper.
Note: These are raw pieces of sheet metal intended to be machined, and may have small surface blemishes, scratches, or printing.
Tensile Strength (PSI)
45,000
Yield Strength (PSI)
40,000
Shear Strength (PSI)
31,000
Elongation in 2"
12
Brinell Hardness
95
Cut Tolerance
+/- 1/4 in
Dimensions
12 in × 12 in
Form
Sheet
Material
Aluminum
Thickness Tolerance
+/- 0.0150 in
