Hello this is a remake of MWP Dust shields he gets all the credit for the original design
What I did:
I added a spacer block for the dust shield ends along with extra holes in the actual dust shield for mounting purposes
Please follow all his instructions I just want to share my files
The author’s moral rights;
So please follow all MWP instructions but you need to cut 4 of these pieces out all I did was add some additional holes to them to better secure them to the markerslide
I used :
2 flute solid carbide spiral downcut .125 bit
Cut little spacer blocks
So please follow all MWP instructions but you need to cut 4 of these pieces out these will allow you to have the proper spacing from the makerslide when using the additional holes in the main dust shield
I used :
Nice addition to my project, I'll be sure to link to this. Thanks for the upgrade!
Robert Rieke
Robert Rieke
