No Derivative Works — You may not alter, transform, or build upon this work.
The author’s moral rights;
Charles - I am about to kick off a project much like what you have done. Are you willing to discuss what logic boards you are using and what it takes to switch from CNC to 3D??
Randy Buster
Of course, the electronics I used was an arduino mega 2560 with a Ramps 1.4 electronics board. These should be reflected in the bill of materials document (.csv) under the digital files section. If you have any other questions feel free to ask!
Charles Modrich
Did you build your own extruder or buy a turn key design?
Gregg Harrington
This is the Extruder that I used: http://tinyurl.com/nbpmznf
Would not recommend that one again though, it clogs way too much for my liking. I did have to make my own fan setup though, I created a fan shroud to attach a dc cooling fan aimed at the print surface.
Charles Modrich
Randy Buster
Charles Modrich
Gregg Harrington
Charles Modrich
