Aluminum GT2 Pulley - 20 Teeth, Dual Flange - 20 mm Pitch
Aluminum pulley with dual set screws
  • Aluminum GT2 Pulley - 20 Teeth, Dual Flange - 20 mm Pitch
Price Part Number Bore Belt Width
$6.99 1/4 in 6 mm
$5.49 8 mm 6 mm
The GT2 series of belts and pulleys are designed specifically for linear motion. They use a rounded tooth profile that guarantees that the belt tooth fits smoothly and accurately in the pulley groove, so when you reverse the pulley direction, there is no room for the belt to move in the groove.
This pulley is intended to be used in conjunction with GT2 belting, such as 26053-01
Flange
Dual
Pitch
2 mm
Trade Name
GT2
Files & Attachments
CAD File (STEP)
26054-03.zip
CAD File (STEP)
26054-02.zip
