Adjusting Dust Rails
98 opens
36 copies
589 downloads 3 comments
David Randolph
David Randolph
Silver Spring, USA
This is a remake of some wonderful design work over at Inventables https://www.inventables.com/projects/mwp-y-axis-braces and https://www.inventables.com/projects/mwp-y-axis-belt-dust-guards
Aluminum Sheet 6061
Aluminum Sheet 6061
Dimensions: 12 in × 12 in × .125 in, Thickness: .125 in
Clear Acrylic Sheet - Cast
Clear Acrylic Sheet - Cast (×2)
Dimensions: 18 in × 24 in, Thickness: 1/8 in, Material Type: Extruded
$32.34
Hex Nuts
Hex Nuts (×2)
Height: 2.4mm, Pitch: 0.5mm, Quantity: 10, Width: 5.5mm, Thread Width: M3
Post-Assembly T-Slot Nuts
Post-Assembly T-Slot Nuts (×4)
Thread Size: M3 (3mm) × 0.5, Qty: 10 pack
$41.96
Socket Head Cap Screw - Packs of 10 each (×6)
Length: 10mm - 2012 - 2019, Quantity: 10, Thread Size: M3
$74.30
x-carve-rails.dxf
DXF of whole rails
x-carve-rails.cdr
CorelDraw of whole rails
x-carve-rails-cnc.svg
SVG of rails split for X-Carve
Introduction
This is a remake of some wonderful design work over at Inventables https://www.inventables.com/projects/mwp-y-axis-braces and https://www.inventables.com/projects/mwp-y-axis-belt-dust-guards There wasn’t any source files so modification wasn’t very easy. So I remade it from scratch and narrowed down the materials needed.
Be sure to reference Robert Rieke work in the links above for more detailed instructions since this is really just a variant of his work and all credit should go to him.
I also posted these files over on thingiverse http://www.thingiverse.com/thing:1844698
If you have a large enough laser cutter you can cut these as one piece. I changed the holes to fit M3 hardware and slotted them so you can move the side rails up/down and flush to the wasteboard.
I also made a front/rear variant that you can use the same braces to hold them in place.
.25" 6061 aluminum sheet to mill out 9 or 12 pieces of the stiffeners.
.125" acrylic sheet to mill or laser cut out the side plates and front/rear plate.
54 M3-10mm Bolts
36 M3 Drop-in extrusion nuts 2020 size
18 M3 regular nuts
Made one? Log in to add yours
Geno Nemetz
I picked up the materials, and about to start this. What bit did you use, and what were your cutting settings?
Geno Nemetz
Geno Nemetz
Ended up following Robert's write up. Almost finished with mine. Thanks for the files!
Geno Nemetz
Bug Bolito
thank you for the files , it was my 1rst cut , I use 3mm vinil
Bug Bolito
