Upgrade the rigidity, precision, and gantry clearance of your X-Carve with Z-axis and height improvements in this kit. With an additional 2 inches of Z-axis travel, this kit will nearly double the carvable volume of your X-Carve.
NOTE: X-Carve Machines purchased 2015 or earlier will need updated Z stepper motor cable assemblies.
Includes |
Direct Drive Z-Axis with upgraded 212 oz-in stepper motor (+50% torque) |
2" Risers (4) |
Acrylic Dust Guards / Stiffeners (8) |
Installation Time |
60 minutes |
Installation Instructions |
It’s quite simple, actually, and shouldn’t take longer than an hour with our easy-to-understand instructions.
Great! You’ll maximize the performance gains AND you can save money by purchasing both together in our Ultimate X-Carve Upgrade Kit.
The overall height is 21 1/4".
To get the most out of this upgrade, we highly recommend using the X-Controller Kit and the Wide Makerslide.. While the new stepper motors can be run on the original g-shield controller, you will not be getting the full benefit from the upgraded motors.
