With this upgrade kit, your X-Carve is just 90 minutes away from higher material removal rates, cutting speeds, and reliability. Replaces the 6mm wide 2GT belts with 9mm wide 3GT belts and stepper motors with 50% more torque.
NOTE: X-Carve Machines purchased 2015 or earlier will need updated X, Y1, and Y2 stepper motor cable assemblies.
Includes |
9mm 3GT belting (3.5 meter) |
9mm belt clips (6) |
9mm belt sleeves (6) |
9mm wide belt idlers (6) |
212 oz-in NEMA 23 stepper motors for X and Y with 50% more torque than stock (3) |
Installation Time |
90 min |
Installation Instructions |
It’s quite simple, actually, and shouldn’t take longer than 90 minutes with our easy-to-understand instructions.
Great! You’ll maximize the performance gains AND you can save money by purchasing both together in our Ultimate X-Carve Upgrade Kit.
To get the most out of this upgrade, we highly recommend using the X-Controller Kit and the Wide Makerslide. While the new stepper motors can be run on the original g-shield controller, you will not be getting the full benefit from the upgraded motors.
