Mon - Fri: 9am - 5pm CT
Sun 12pm – 4pm CT
X-Carve Eccentric Spacer Upgrade
Convert X-Carve 2015 to X-Carve 2016 eccentric spacers
Price Part Number Description
$10.00 Eccentric spacers and related hardware
Ever experience your eccentric nuts loosen and fall off of your 2015 X-Carve? This upgrade pack replaces those eccentric nuts with our new eccentric spacers and includes all of the necessary hardware to make the switch. Now with the spacers and nylon insert lock nuts, you should no longer experience hardware falling off of your machine.
This kit contains:
Qty Product Dimensions
8 Eccentric Spacer 0.20 in
2 Eccentric Spacer 0.375 in
2 Aluminum Spacers 5.1mm ID 9.5mm OD 9.5mm LG
4 Button Head Cap Screw M5 x 40mm
8 Button Head Cap Screw M5 x 30mm
12 Nylon Insert Lock Nut M5
For those needing help with installation, refer to the latest X-Carve instructions here:
x-carve instructions
Add your project
