Mon - Fri: 9am - 5pm CT
Sun 12pm – 4pm CT
X-Carve 1000mm Waste Board Kit
Single waste board with support for clamping.
  • X-Carve 1000mm Waste Board Kit
Price Part Number Description Machine Size
$149.00 $79.00 Waste board with threaded inserts and hardware 1000mm
This is a waste board for X-Carve that has the following features.
  • Pre-drilled and counterbored holes for M5 threaded inserts to attach clamps
  • Silkscreen pattern to show the general work area of the machine
  • Easy installation by sliding in from the side without having to disassemble the machine
  • Extra mounting holes in the middle of the board in case you want add (2) cross members for additional support.
  • Works great with our Clamp Set for 3D Carving
  • Mounting hardware and threaded inserts included
Assembly Required
There is some final fabrication required by the end user for this product to function. The inserts need to be installed. We have instructions that demonstrate how to do this. Please note the inserts go in from the back side.
Boards have provisions for adding additional cross members underneath for support. This is strongly recommended for the large version or it will sag over time.
If you purchased your X-Carve after 11/2/2021, you will need additional hardware to make this wasteboard compatible with your machine:
1 x 25281-02 Pre-Assembly T-Slot Nuts
1 x 26018-03 Extrusion Brackets
1 x 26049-04 Aluminum Extrusion – 20mm x 20mm x 958mm
Note
The material is MDF. There may be small scratches, discoloration or scratches on the surface that do not affect performance.
Add your project
