Silver Glitter Acrylic Sheet
Silver sparkles add depth as light reflects off the surface
  • Silver Glitter Acrylic Sheet
$40.16 12 in × 24 in 1/8 in
This striking sheet contains silver specs of glitter. It can be laser cut and milled.
Due to the manufacturing process, the sheet’s surface may not be entirely smooth – there can be divots. The concentration of glitter also varies by batch, with some sheets having very dense glitter and some sheets having a more sparse glitter pattern. This is an unavoidable part of the manufacturing process.
Color
Silver
Effect
Glitter
Opacity
Translucent
Surface Finish
Glossy
Thickness
1/8 in
Thickness Tolerance
± .05 in
