NEW: Try 3D in Easel Pro. Learn More
Red MDF Sheet
Strong, organically dyed wood fiber panels
Red MDF Sheet
$11.31 8 in × 12 in 1/4 in
Features
  • Easy to machine
  • Non-toxic
Cut tolerance
+/- 1/16"
Color
Red
Thickness
1/4 in
Type
MDF
Files & Attachments
Data Sheet
Colored MDF Data Sheet.pdf
