This King CuttingColors® HDPE sheet has a textured, matte finish and solid surface to provide a stable and sanitary work area. Bacteria, odors and cleaning fluids wash completely off. The material won’t dull knives. It is produced with FDA-approved materials and and is tested and certified by the NSF. The bright color is great for making a fun cutting board with both function and style.
Try combining this colored sheet with our Bamboo Plywood to make an interesting inlay for your cutting board.
Cut tolerance |
+/- 1/8" |
Color |
Red |
Surface Finish |
Textured |
Type |
Single color |
Hello. I have a plan to make DIY portable tandem kayak, which will consist of 4 modules. During transportation kayak will seat in the trunk of car. Well, I am looking for 2 sheets of easiest welding, UV stabilized HDPE 1/8"×48"×96" each, preferably in a green, yellow or white color. I am going to weld HDPE sheets by using my hot air gun. How much for sheet and
for shipping? Do you know any plastic distributor near zip code 33426, Florida? Thanks for your answer.
Is it available in 1/8" thick?
Is it available in 1/4" thick?
Thanks.
We would need a sheet that is around 48 × 48. Could you provide a quote for a sheet that size if you can make it? My last question is can it be made in a blue and red color?
1 answer
