Purple Glitter Acrylic Sheet
Purple sparkles add depth as light reflects off the surface
  • Purple Glitter Acrylic Sheet
This striking sheet contains purple specs of glitter. It can be laser cut and milled.
Due to the manufacturing process, the sheet’s surface may not be entirely smooth – there can be divots. The concentration of glitter also varies by batch, with some sheets having very dense glitter and some sheets having a more sparse glitter pattern. This is an unavoidable part of the manufacturing process.
Color
Purple
Effect
Glitter
Opacity
Translucent
Surface Finish
Glossy
Thickness
1/8 in
Thickness Tolerance
± .05 in
Q & A
Ask a question about Purple Glitter Acrylic Sheet
Kenneth Clapp
Suggested setting for laser cutting?
I know you can’t necessarily tell me the exact setting for my machine, but any suggested starting points for a 40w CO2 laser?
1 answer
Ottava Designs
How to avoid whiteness when laser cutting?
Any hints on avoiding a white sort of melted outline when laser cutting the glitters, especially the darker ones?
1 answer
