Mon - Fri: 9am - 5pm CT
Sun 12pm – 4pm CT
Pre-Assembly T-Slot Nuts
Inserts into an aluminum extrusion. Provides mounting point to attach components.
  • Pre-Assembly T-Slot Nuts
Price Part Number Quantity Thread Size
$5.00 10 M3 (3mm) × 0.5 (non X-Carve)
$5.00 10 M5 (5mm) × 0.8
Pre-assembly insertion nuts are used to fasten objects to standard 5 series aluminum extrusions (including makerslide). These nuts are used in conjunction with a fastener such as a socket head cap screw and a flat washer. Simply insert the nut into the extrusion prior to assembly.
Made from Low Carbon Steel with a Trivalent Chromate surface finish.
These are also commonly referred to as T-Nuts, Tee Nuts, or Extrusion Nuts.
Insertion Type
Pre-Assembly
Type
Insertion Nut
Files & Attachments
CAD Files (STEP)
25281.zip
