Mon - Fri: 9am - 5pm CT
Sun 12pm – 4pm CT
Plywood Table 01 by Ben Uyeda
Build your own plywood table with designs from Ben Uyeda
  • Plywood Table 01 by Ben Uyeda
  • Play
Price Part Number Description
$5.00 Digital design file
Ben Uyeda of HomeMade Modern is designing a series of tables that can be made from 3/4" plywood. This is the first table in that series.
For instructions check out the YouTube video
Note that the easel file does not include dimensions for a table top so that it can be custom fit to your situation. Our recommended range is 24×60 up to 28×64 in.
Includes
Easel Design File
Illustrator Vector Files
Add your project
FAQ
What material will I need to use?
The plans are designed with 3/4 in plywood with the parts arranged on a 24 × 35 in sheet.
What CNC can I use?
The plans are designed to fit a 1000 × 1000 mm X-Carve as well as X-Carve Pro, but any machine will work. Depending on the work area you might need to re-arrange the parts inside of Easel.
Will I need to edit the files?
If your machine has a large enough work area the only change you’ll need to make is to the material thickness since not all plywood is exactly 0.75 in.
