Orange MDF Sheet
Strong, organically dyed wood fiber panels - On Sale!
Orange MDF Sheet
$11.29 8 in × 12 in 1/4 in
Features
  • Easy to machine
  • Non-toxic
  • Perfect for Halloween!
Cut tolerance
+/- 1/16"
Color
Orange
Thickness
1/4 in
Type
MDF
Files & Attachments
Data Sheet
forescolor_technical_data_sheet.pdf
