These sheets can be engraved using a 3D carver, like X-Carve or Carvey, as well as a laser cutter.
Carvey Settings
Carving Bit | Depth Per Pass | Feedrate |
1/8" 1 Flute Spiral | 0.04" | 48"/min |
1/8" 2 Flute Straight | 0.01" | 96"/min |
1/16" 2 Flute Fish Tail | 0.01" | 48"/min |
1/32" 2 Flute Fish Tail | 0.02" | 24"/min |
Please note these are intended as ‘a starting point’ and adjustments in 5% increments may be needed to achieve optimal results. When engraving & cutting the .022” thickness a 10-15% reduction in power would certainly be reasonable.
Thickness Tolerance (0.022" and 1/16") |
± .003 in |
Thickness Tolerance (1/8") |
± .005 in |
Cut Tolerance |
± 1/4" |
Top Layer Thickness |
0.001" |
Recommended Engraving Depth |
0.003" |
