Glow in the Dark and Clear Reverse Laserable Acrylic Sheet
Laserable acrylic sheets that can be engraved from the back
Price Part Number Dimensions Thickness Cutting Depth
$17.49 8 in × 12 in 1/16 in .022 in
While traditional two-color acrylic is engraved on the top, these sheets are designed to be engraved from the back. This exposes the bottom color while keeping the top of the sheet smooth and flat. Please remember to mirror your text or image before engraving so that it is right side up once the sheet is flipped.
This sheet is clear on top and glow in the dark on the back. The glow in the dark side should be engraved for best results. Perfect for Halloween!
Cut tolerance
+/- 1/4"
Color
Clear
Cutting Depth
.022 in
Effect
2 color reverse engravable
Opacity
Opaque
Surface Finish
Matte non-reflective
Thickness
1/16 in
Thickness Tolerance
± .003 in
Files & Attachments
MSDS
Glow in the Dark Laserable Acrylic MSDS.pdf
Add your project
