Mon - Fri: 9am - 5pm CT
Carbide - V-Bit - 60 Deg x 1/8 in SHK
Carbide bits for your v-carving projects
Price Part Number Shank diameter Cutting Diameter Tip Angle Type Ring Color
$22.29 1/8 in 1/4 in 60 Degree V bit Navy
V-bits are great for carving very intricate, detailed designs. When used in conjunction with v-carving software, they add depth and dimension that can’t be achieved with a flat bit.
Our v-bits have an angle tolerance of +/- 1°. They do not have a flat tip tolerance.
Best for Cutting
Plastic, wood, plywood, MDF
Angle tolerance
+/- 1°
