Carbide Tip V-Bit 60 Degree 3 Flute - 1/4 in Cutting x 1/4 in Shank
Pack of 2 - Use with an edge guide to chamfer and bevel edges.
Price Part Number Cutting Diameter Shank Diameter Tip Angle
$65.40 $49.05 1/4 in 1/4 in 60 Degree
The Spektra™ bits feature a nACo® nanocomposite coating with an extreme nanohardness and heat resistance. With a brilliant distinctively-tinted coloring nACo provides additional improvements in four critical aspects of router tooling.
nACo coating is a micro-thin ceramic coating which enables the tool’s cutting edge to retain crucial sharpness and lubricity. This provides longevity and produces cutting results of the highest quality.
Coating prevents high heat and oxidation which is detrimental to cutting tool performance.
Multi-colored hues, while attractive, will dissipate upon use and yet coating will remain fully effective.
nACo offers approximately 4,500 Vickers for impressive solid hardness on cutting areas of the tool, for an increase up to 2.5 times compared to uncoated bits.
Note: Blue based color dissipates immediately upon use. nACo® nanocomposite coating will not wear off.
Pack of
Add your project
