Bronze Metallic Acrylic Sheet
Achieve the look of metal in a sheet that can easily be laser cut
  • Bronze Metallic Acrylic Sheet
These sheets can be cut, drilled, routed, laser cut, glued, formed, hot stamped and silk screened. While the color and texture may vary slightly from batch to batch, one side will always be matte and one side will always be glossy.
There may be a few small marks and/or indentations on the surface of the sheets. This is an unavoidable part of the manufacturing process.
Color
Brown
Effect
Metallic
Opacity
Opaque
Surface Finish
Matte non-glare (1 side)
Surface Finish
Metallic
Thickness
1/8 in
Thickness Tolerance
± .05 in
Add your project
