I use this to align the X-Y axis when starting Up the machine. I used 2.4mm GRP, with a 2mm end mill bit.
I place one either side, pull the gantry forward until it touches on both sides and then switch on the machine.
I added the red cord so it doesn’t get left on the CNC accidentally (again).
The author’s moral rights;
