X-Carve Y Axis Fenders
Allen Kerr
Allen Kerr
St. Louis, USA
Made plexiglass dust fenders for Y axis on my X-Carve machine
Clear Acrylic Sheet - Cast
Dimensions: 12 in × 24 in, Thickness: 1/8 in, Material Type: Extruded
$10.34
$10.34
Y_axis_fenders_assembly.iges
Fusion 360 Model designed in AutoCad
1001_cutout_01.nc
Fusion 360 CNC file
Y_axis_fenders_assembly.dwg
AutoCad design file
Y Axis Fenders
Working on step by step but not done yet. These are the drawings I used to make these. Start with an acrylic sheet that is 1/8" thick. I used a piece that was 6″ × 24″ to cutout parts. The construction of the fenders is intuitive, but I used a heat gun to shape the kerfed panel and then used MEK to weld the joints together. The pictures shown are prototype in nature and will do another set and make them look better.
Terry Edwards
Great job I would love to have the plans because dust is a real problem.
Terry Edwards
Allen Kerr
If you are still looking for these fenders, I have posted the files I used to make my prototypes. Let me know if you make a set and how they work....thanks
Allen Kerr
Dave Rodman
Nice. I like the idea. What bit did you use to cut/carve it? Also, if you do not mind, what were your settings? Again, nice.
Dave Rodman
