Wood and clear acrylic picture frame
Arturo Duarte
Arturo Duarte
A picture frame designed to keep you photographs protected between wood and and a clear acrylic. It works as a pressurized system. This is a fast an easy way to assemble a picture frame without having too much to worry about how to hang it or having to deal with nails and adhesives.
Clear Acrylic Sheet - Cast
Dimensions: 8 in × 12 in, Thickness: 1/8 in, Material Type: Extruded
$4.99
Padauk
Padauk
6" × 12" × 1/8" Padauk
$8.47
$13.46
Picture frame_small_FINAL.ai
Basic template adjustable to your size project. You cut two pieces from your template, one as wood backing and the other from clear acrylic.The holes on the corners are cuts to insert screws with hex nuts, and washers. Attach a hanging piece at the end.
Hanging piece #6.ai
This piece allows you to hang your picture. this is added at the very end of the screw with washers and hex nuts.
