welcome box
7 opens
1 copy
Ahmed Bahaa Eldeen
Ahmed Bahaa Eldeen
i wanted to make a simple illuminated box, showing our lab welcome sign, i already made it from card board.
31% Light Transmission White Acrylic Sheet
$7.49
Instant Bonding Glue - INSTANT JET™
MDF Wood
MDF Wood
Dimensions: 12 in × 12 in, Thickness: 1/8 in
$2.99
Powered LED Strip - Warm White
$10.48
carve the model
just open easel then connect your carvey and follow the steps generated by the program
preparing the box
cut the tabs and glue the box pieces together and then add the led strep on the back of the box or on the perforated piece, or if you do not have the led you can make your own by inserting the leds in the holes of perforated piece it will hold 5mm leds then connect them.
acrylic
add the acrylic piece in the front in its position then glue
finsh
you can paint the box or leave it as its its a personal point. or can rap it with vinyl.
foil (optional)
i covered the interior of the box by foil using double sided tape for more illumination
