Weight Reduced Bracket for Air Diverter
WorkinWoods
WorkinWoods
Hello everyone this is a bracket for the Dewalt 611 air diverter plate this bracket will provide a solid mount across the entire plate along with mounting holes for other accesories
Black HDPE Sheet
Black HDPE Sheet
Dewalt air diverter bracket v4.iges
Here is the file in iges format for Fusion 360
Dewalt air diverter bracket v4.step
Here is the file in step format for Fusion 360
airbracket3.nc.nc
Here is the gcode file for Universal Gcode sender make sure to open in a editor before you use on your machine
CARVE THE PIECE
Alright everyone this bracket is for the Dewalt 611 air diverter plate that I remade and will provide a solid base across the entire plate
I made this one in the photos as a mock setup but the final version will be made out of .125" HDPE for more strength
All the holes are for weight reduction while still maintaining its strength plus this provides mounting holes for a 2.5" vacuum hose so there is no strain on the plate
I made this in Fusion 360 and cut it using Universal Gcode Sender so I supplied the .nc file you can load this file up and simply cut away
or possibly you can import the g code directly into easel just let me know if you need anything else I warn you though I did not use a x-carve friendly post processor so you cannot raise the bit before cutting so just make sure that your material is extremely flat
Aaron Maun
Is it possible to get the file for Fusion 360 so it can be edited for different thickness and material?
Aaron Maun
WorkinWoods
yup I will add it now no problem
WorkinWoods
