Cut in to 1/8th inch stock. Main photo is one that I made for our wedding. Anyone with the last name is free to use it. For everyone else, there are a few more included in this project:
“Best Day Ever”
“Love You More”
“Mr & Mrs”
“Sh*t just got real”
hi.. do you have a step by step process to make this? thanks in advance
Jocelyn Lopez
Hi Nate
I have been trying to make a cake topper, but oo Im struggling, any advice as to how i can design 1
Bianca
@Bianca The shapes were created in another program and imported as svg in to Easel. Unfortunately other than changing the scale and thickness in Easel, not much can be modified here.
Nate Fanaro
@Jocelyn You should be able to your stock's thickness in easel, and use a small bit to carve. There are tabs in the design to keep everything in place but double sided tape might work better. If you need additional help I would recommend using the forums.
Nate Fanaro
what software did you create the shapes in before moving it to easle? do you have the editable file so we could change the name on the topper?
Tim Walsh
Added a few screenshots of the other sayings in the project. This was designed in Illustrator.
I do not have the original file handy. It isn't as simple as typing new text and saving the file. This still should be easy to reproduce. Just be sure the text is touching
Nate Fanaro
Mike Carter
Nate Fanaro
Ashley Stillson
Nate Fanaro
Jacob AuBuchon
Nate Fanaro
Jocelyn Lopez
Bianca
Nate Fanaro
Nate Fanaro
Tim Walsh
Kevin Dailey
jacob brower
Nate Fanaro
