Wall Clock
26 opens
8 copies
Alexandru Raican
Alexandru Raican
Corbeanca, Romania
I wanted to make a large wall clock and I had a clock mechanism.
Thank’s to the Easel Pro the carving with a 60 dg V bit looks great.
Carve
90 minutes
When you carve it modify the height of the Z probe with 1 mm less than it is in order for the topography to sow up.
Clean
45 minutes
Clean everything and prep for paint. I used a sealer before carving in order for the paint to not get sucked to deep in the wood.
Paint
Paint over the carved parts.
Sand everything
Very important to wait for the paint to cure otherwise you end up like me and using 15 sanding pads because the paint buildup.
Finish
Apply some finish.
