US Navy Officer Crest
1561 opens
396 copies
26 comments
Troy Brady
Troy Brady
KY
This was made for a customer requesting the US Navy Officer’s crest with the person’s name at the bottom. I used 50 stars in a circle around the plaque.
Ryan Mulcahy
GO NAVY BEAT ARMY!
Ryan Mulcahy
MOHANNAD
its so nice good job
MOHANNAD
Charles Daily
Can you share this project?
Charles Daily
Dean Bielitz
Please share this project. Great gift for my brother...
Dean Bielitz
Donald Freas
very nice!
Donald Freas
Louie Podunavac
could you please share this project? I tried opening it and it says it isnt shared publicly?
Louie Podunavac
Alan G Miller
Did you do this all in acrylic?
Alan G Miller
Troy Brady
Sorry for the delayed response. This should be shareable now. The project is in pine, I use the acrylic material to show detail only.
Troy Brady
Gordon Lewellen
What Bit did you use?
Gordon Lewellen
Troy Brady
Hey Gordon - I used a 90 degree V bit for everything except the cutout. I used a 1/4" spiral bit to cut the pocket and a 1/8" to cut out the insignia.
Troy Brady
Duane Heda
Troy, love his crest. After Vietnam my door gunner enlist in the Navy and spent over 20 years retiring as a Captain and really want to make this for him. One of my questions, I say "one" because there might be more, how do I edit the name?
Duane Heda
Troy Brady
Hi Duane - Glad you like it! I use Adobe Illustrator for my text, but you may be able to use Easel to curve your text.
Troy Brady
Duane Heda
Apparently the whole file is locked and will not allow me to do any editing. Any chance of you unlocking it????
Duane Heda
Troy Brady
Hmm... it doesn't appear to be locked on my end. Not sure what's happening.
Troy Brady
Troy Brady
Try this - https://easel.inventables.com/projects/bEhq2qanghSypFjme2Uhkw
Troy Brady
Duane Heda
No luck. I don't understand either. Guess I'll do more checking on my end end. But this the only file I seem to having trouble with. think I'll try another file from this site and see what happens.
Duane Heda
Duane Heda
Found the problem Tony. The workpieces were locked. I clicked on the lock icon and no more problem!!!
Duane Heda
Duane Heda
How do you edit the persons name?? Also, I routed and cut the crest and it came out perfect!!
Duane Heda
Troy Brady
I don't think it can be edited in Easel. It was originally created in Illustrator and converted to an SVG file, then imported into Easel.
Troy Brady
Duane Heda
I just now got it figured out. I went to Light Burn did the edit and exported it as a svg file and exported it to Easel. Doing a test run as I type this and looks good. Thanks for your time and help.
Duane Heda
Troy Brady
My pleasure!
Troy Brady
Donald Cale
Troy, Nice job. I'm a retired CPO and new to XCarve. I have a couple of questions do you have this file set up for a Chief or Senior Chief ? That was my rank. I am try to use the file you shared and having a hell of a time with the letters.
Donald Cale
Troy Brady
@Donald Cale - If you'll give me your email address, I'll send you a Senior Chief file you can use.
Troy Brady
Donald Cale
donald_cale@yahoo.com
Donald Cale
Brad Sylvester
Is this made from two pieces, one on top of another, or is everything outside of the eagle carved lower?
Brad Sylvester
Troy Brady
Hey Brad - It is made from 2 pieces. The top piece is about .7" thick and is inlayed about .25" into the bottom piece (1" thick).
Troy Brady
