Topographical map
Fernando Romero
Fernando Romero
Houston, USA
Topographical map of a ranch in central Texas.
Made from layers of 0.170" thick plywood.
Mattison Donaldson
What program did you use to get the topographic map? I'm having trouble finding one for a school project.
Mattison Donaldson
Fernando Romero
The map itself I downloaded as a PDF file from the University of Texas (http://legacy.lib.utexas.edu/maps/topo/texas/). I then used an online converter to go from PDF to DXF. I then used autocad to cleanup and extract the curves I wanted to use. Then I imported the DXFs directly into easel.
Fernando Romero
