TonieBox Holder
27 opens
7 copies
2 comments
Joshua Gibb
Joshua Gibb
I decided to design a holder for a product (TonieBox) that we brought for your 2yr old son.
I wanted to design something that would incorporate the TonieBox itself, a selection of the Figures (these contain the music or stories that play on the box), and the charging stand.
Blue MDF Sheet
Blue MDF Sheet (×3)
Dimensions: 8 in × 12 in Dont use, Thickness: 1/4 in
Laminating (Gluing) Material Together
Glue the 3 pieces of the MDF 12″ × 12″ × 1/4" together creating 3 layers to make up 3/4" think board.
-Layout two pieces of material beside each other and cover with wood glue.
- Lay the 3 pieces of material face to face with one side with glue to a corresponding face that doesn’t have glue.
- Use clamps or some form of weights to press the material together and leave to dry. Do your best to keep all edges flush.
CNC Millling - Backside for Charger Station Cable
3 minutes
- Place the Material on the X-carve and mill the backside first, the slot for the Charger Station Cable
CNC Milling - Topside
42 minutes
-Turn the Material over (With the milled slot on the left underside) and mill the frontside of the Project.
Finishing
- Once the milling is finished, remove from the X-Carve and remove the project from the rest of the material by cutting the tabs.
- Sand the edges and remove sharp edges so it is a little rounded.
- Finish with a clear lacquer from a spray can or a wax or oil of your choosing.
Shawn Calligan
Will you please share a photo of the finished shelf? Thank you!
Shawn Calligan
Joshua Gibb
Shawn Calligan. This was a concept for a design, to go in the draw to win a cnc from Inventables at the time. I did t actually end up making and completing the project. So sorry, I dont have a photo of a finished product.
Joshua Gibb
