Tic Tac Toe With Two Twenty Five
470 opens
183 copies
750 downloads 1 comment
Beyond Design
Beyond Design
Chicago, Illinois
A smaller sized game of tic tac toe for use on your desk, coffee table, or travel. Use quarters in a game of tic tac toe with heads competing against tails, or create and customize your own pieces. It is a minimalistic design showcasing the the textures created by the tool paths.
Tortoise Shell Acrylic
White Corian®
White Corian®
Color: White, Dimensions: 10 in × 12 in, Thickness: 1/2 in, Cut Tolerance: +/- 1/2 in
tictactoe_parts.svg
SVG of all parts
Mill The Base and Lid
First cut will give you your base and lid. This will be the longest cut. We used an 1/8th" ball nose so the texture of the tool path would remain on the underside of the lid and the circles, which will be your playing surface.
Use this EASEL link
X|O Symbols on Lid
Second cut we used a 1/16th" square end mill to keep the X and O clean. For this cut you need to flip the lid over from the previous cut and position it in the corner of your machine to get it centered.
Use this EASEL link
Accent Inlay for Playing Surface
The last piece is the accent inlay. We used the 1/8th in tortoise shell acrylic to contrast the white corian. The bit was the same 1/16th" as the X and O cut.
Use this EASEL link
Insert Inlay and Play
Final step in to press fit or glue the accent inlay onto the playing board. Once that is complete, find some quarters and play… or create your own pieces to play with
Jason Hughes
Can you share the project publicly? It is private right now.
Jason Hughes
