Tic-Tac-Toe Board Game
0 opens
0 copies
5 comments
Linda Haynes
Linda Haynes
Perth, Australia
Learn how to make a DIY Tic-Tac-Toe game. A homemade wooden Tic Tac Toe game is fun for all ages and makes a thoughtful handmade gift. This educational game can help teach important strategy skills. Depending upon your skills, you can create this project in about one or two hours.
Walnut (×2)
6" × 12" × 3/4" Walnut
$22.86
Add to Cart
$22.86
Materials needed
One piece of wood approximately 1.5 in. × 6.5 in. × 6.5 in. (4cm x 17cm x 17cm). In my case, I am using a piece of walnut.
Two wooden dowel 3/4 in. (2cm) in diameter. If you only have only type of wood for the dowels, you can paint one set of pegs a different color.
The size of the board and your pegs can easily be modified to match the materials you have on hand. This project can be completed with just a basic hand saw, a drill, and a drill bit. However, I have included pictures of other power tools that can be used to speed up the process. Buy it from Catch store with Catch coupon code.
Saw board to match dimensions of Tic Tac Toe Game Board
Using a hand saw, table saw, or miter saw cut the board to 1.5 in. × 6.5 in. × 6.5 in. (4cm x 17cm x 17cm).
Mark horizontal and vertical lines
Cut these lines to a depth of approximately 1/8in (0.3cm) using either a hand saw or a table saw.
Mark holes for pegs
Drill holes 3/4 in. (2cm) in diameter, approximately 3/4 in. (2cm) in depth. If using a drill press, you can set the depth stop. This will ensure all the holes are drilled to the same depth.
Cut ten wooden dowels 2 in (5cm) in length
Ideally cut five pegs from a darker wood, and five pegs from a littler wood. However, if you only have one type of wood, you can paint five of the dowels a different color.
Ensure the pegs easily fit
Ideally, you want the pegs to go in easily. If you have a huge selection of drill bits, drill the holes slightly larger than the pegs. Since I did not have a bit slightly larger than the dowels, I enlarged the holes using a Dremel with a sanding attachment.
Sand and smooth the edges
If you have access to a router, you can use this tool to round the top edges.
Apply a finish to the Tic-Tac-Toe Game Board
In my case, I applied a linseed oil to the walnut wood.
9
Enjoy and have fun
Now enjoy the game with your family or friends.
Tic-Tac-Toe Rules
Two players take turns inserting pegs into the holes or spaces in the 3×3 grid. The player who succeeds in placing three of their pegs in a horizontal, vertical, or diagonal row wins the game
williamjordan
Buy Car Engine Parts online, OEM Parts OEM Quality Parts in London Auto Parts Store. All Models include Audi, For our Engine products Call Now! <a href="https://www.apexautoparts.co.uk/">Auto Parts UK</a>
williamjordan
williamjordan
Buy Car Engine Parts online, OEM Parts OEM Quality Parts in London Auto Parts Store. All Models include Audi, For our Engine products Call Now! https://www.apexautoparts.co.uk/
williamjordan
Farhad 99
Thanks for sharing this amazing article, it is a very informative post good work keep it up. https://coupontoaster.com/healthexpress
Farhad 99
Keeley Nienow
Hi this is Keeley Nienow, a professional Affiliate Marketer. If you are looking for Health & CBD Coupons, you can visit [url=https://savingted.com/]Saving TED[/url] which is having huge amount of Healh related and much more stores.
Keeley Nienow
Ethan Garcia
This is so a fantastic article. Thanks for sharing this informative article. <a href="https://sports-surge.com/category/basketball/">Sports Surge Basketball</a>
Ethan Garcia
