Thanksgiving Turkey Bases/Christmas Ornaments
60 opens
19 copies
Kevin Loeffler
Kevin Loeffler
Arvada, USA
A simple Thanksgiving party favor that doubles as an ornament for the next big holiday! I carved the ones in the images in bamboo and placed some chocolate turkeys on top.
Bamboo Plywood
Bamboo Plywood
Load the Easel Project
Using this project, load the attached Easel project.
Load wood into your 3D carver
Ensure that the wood is clamped down securely. Note: You probably want to measure it before you load it in your machine.
Adjust settings for your cutting bit/board thickness
In Easel, confirm you have selected the right settings for your machine and setup.
Carve the leaves!
120 minutes
Carving takes a significant amount of time, so be sure to plan ahead! 2 hours is sufficient to carve five leaves.
