This is a template for a huge Jenga set. The size of each Jenga piece is
258mm*86mm*36mm. This template has 12 Jenga pieces. To carve this you will need an X-Carve. The questions have a place that says “add your own thing” in this spot you can erase it and change it to the question you want
