Support closed Sunday 4/2
Switch Game Case
213 opens
109 copies
20 comments
joe mchug
joe mchug
This is a Nintendo Switch Game Case that holds 8 games. The machining is all done in 60 minutes using the recommended settings for walnut. The entire box is done within one carve, excluding the engraving on the top.
HSS Upcut 2 Flute - 1/4 in Cutting x 1/4 in Shank
Onsrud-brand bit with 1/4" shank and cutting diameter for cutting woods and soft metals
$14.45
MDF Wood
MDF Wood
Dimensions: 12 in × 24 in, Thickness: 1/2 in
$10.00
Pure Tung Oil
Pure Tung Oil
8 oz bottle of pure tung oil
$28.54
Sanding Sponge
Sanding Sponge
Fine/Medium Sanding Sponge
$6.49
6" × 12" × 1/2" Walnut
$59.48
Cut walnut to size
Cut the 6’’ x 12’’ piece of walnut to 4.25’’ x 10.75’’. This can be done using a table saw, circular saw or even a hand saw if need be.
Work holding
3 minutes
I used double stick tape to hold the work piece. This is important to have access to the profile of your part; otherwise, you will not be able to finish this project. Be sure to use some sacrificial material under the part. One could also build a jig out of some sacrificial material such as MDF, which is why I added it to Bill of Materials.
Setting home position,
This is the most important part of this project. It is very important that the center of the end mill is at the center of the bottom left hand corner. Proper alignment is critical for success. This can be ensured by first aligning the X axis. This is done by moving the end mill slightly until it touches the side of the material, and then the Z axis is raised up above the part, and then the X axis is moved to the right by half of the tool diameter. Repeat this step for the Y axis. After this is done, lower the Z axis until the end mill is on the surface of the material.
Carve
This is the actual carve process that the project takes. The main one that carves out the box, which takes 56 minutes using recommended settings for 1/4’’ end mill and an engraving that goes on top of the lid that takes 4 minutes using recommended settings for 1/16’’ end mill .
Finish Work
The box will require some sanding because the tolerances are tight; however, this is done on purpose because of slight variances in accuracy from machine to machine. The exterior and interior sides will need to be sanded to allow proper fitment. Sand until it is a tight fit, but the lid should not be very difficult to remove. finally apply finish and allow to cure.
Audrey Van de Castle
Can you share this publicly so we can make it? Thanks!
joe mchug
OK should be fixed now.
joe mchug
Chris Feeley
It still says it is not shared publicly.
Chris Feeley
joe mchug
OK definitely fixed this time I did not realize both the project and file need to be public. First time I have posted a project here.
joe mchug
Chad Forrester
It unfortunately still says "This project has not been shared publicly". Would you mind taking one more shot at sharing it?
Chad Forrester
Connor Fatzinger
it still says project has not been shared publicly yet.. can u please share it again? thanks
Connor Fatzinger
Eli hughes
Hello! Can you share the G Code for this?
Eli hughes
Chris Wineland
Please share, this would be great for Christmas
Chris Wineland
Chris Wineland
Please make this public
Chris Wineland
Edward Colee
file still shows not public. Can you fix?
Edward Colee
Victoria Michels
I would really love to make this but it says it is not public, can you please fix?
Victoria Michels
Cyber Ogre
Hello. This is a great design. Would you mind sharing it so that I could grab the code? Thanks!
Cyber Ogre
Eddie Young
Hi I like this design i am wanting to know if you can share it i would like it to be my first project.
Eddie Young
Mohammed Adenwala
Would be great full to see the easel project .. thank you!
Mohammed Adenwala
Christopher taylor
Can you please share the file
Christopher taylor
Margaret Wesley
I'd like to try making this for a present. How do I get access?
Margaret Wesley
Adam St. Louis
I can't tell the dates on these comments but the project still says it's not private. Can you share the files with us?
Adam St. Louis
Ahron O.
This would be awesome for me. please share!
Ahron O.
Mark Schlueb
Still not public 3/21/21
Mark Schlueb
Cathy McAndrew
As of May 5th, still not sharing
Cathy McAndrew
