My 8th-grade students designed their own locker tags.
They obviously have to follow a list of specifications:
Plate: L = 101 mm x H = 76 mm. HPDE bi-color – thickness = 3 mm
Bit: diameter = 1.6 mm.
Machining depth = 0.3 mm.
First name + Last name + Class in French ONE Illustration
The author’s moral rights;
