Star Wars Coasters
2 comments
Michael Zawicki
Michael Zawicki
Merica
Nice solid Oak Coasters with Star Wars images found on google. Made a set for my self and one set for a friend.
Carbide V-Bits
Carbide V-Bits
$15.77
Red Oak
Red Oak
6" × 12" × 1/2" Red Oak
$15.77
Coasters
45 minutes
I used oak sheet i got from a big box store, i think i was 10 bucks for a 4 foot by 6 inch peace that is .25 inch thick. This is made with 2 bits, first is a .0625 for all the flat spaces and then a 60* v bit is used to get all the detail and sharp edges. cut depth is .1 deep. after they are cut out i sand down to a 320 grit and airbrush the surface and sand again to get the detail to show. finally i use 3 coats of a furniture grade high gloss clear poly for durability. The back is 1/8 cork from a hobby store i cut slightly smaller and glue on with a spray glue that is moisture resistant.
2 bit change process
i have a touch plate that i installed into my machine and i use a excel spread sheet that is set up to generate the codes for doing a true Z zero depending on what bit i am using. If you dont have one yet i highly recommend it. mine cost me about 15 bucks. i can help you all the way for installation and use
Gregg Hall
Share?
Gregg Hall
Kenneth Moon
I like it. I may try it and fill with black resin. Thanks.
Kenneth Moon
