Standard 4 Wheel MakerSlide Carriage
Bart Dring
Bart Dring from Inventables
This is a project to show the basic items needed to make a standard 4 wheel MakerSlide carriage. It includes some MakerSlide for reference. You should determine if the piece chosen is right for you. You can edit your cart at any time after adding.
Aluminum Spacers - #12, 5M
$2.99
Button Head Cap Screw
Length: 30mm, Pitch: 0.8mm, Quantity: 10, Thread Size: M5
Dual Bearing V-Wheel Kit
Dual Bearing V-Wheel Kit (×4)
Type: Wheels dont use 1, Qty: 1 dont use 1
Eccentric Spacer
Eccentric Spacer (×2)
Spacer Type: Standard, Qty: 1 don't use, Length: 0.25 in
Hex Nuts
Hex Nuts
Length: 1000mm - 2012 - 2019
Standard Wheel Carriage Plate
Type: Plate
$3.37
$6.36
b30058.stp
CAD File (STEP)
b30058_rev_1.pdf
Technical Drawing
Assemble the wheels
Press a bearing into one side to the wheel. Place the shim washer on the bearing and press the second bearing into the wheel.
The bearing can be pressed in by hand by pushing against a firm flat surface. Make sure the bearings are going in straight.
You can use a 5mm screw to make sure the washer stays centered. If the washer moves it is easy to re-center it later with a thin item like a paper clip.
Install the Fixed Wheels
The wheels are installed on the 4 holes in the corners of the plate. 2 of the holes are smaller at about 5.1mm diameter. These are for the non adjustable wheels mounted on the aluminum spacers.
Install Adjustable Wheels
Place a mark on the eccentric spacer on the surface nearest the center hole. This will give you a reference for adjusting later.
Install the spacers with the marks facing the outside of the carriage. This will start with the wheels in their widest position. Install the wheels now.
When you put the completed carriage on the MakerSlide adjust the wheels so they just light contact the rail. Excessive tightening will damage the wheels and put a flat spot on them.
Richard Beck
Great, I wish I found this before I assemble mind. I put the washer in the wrong place, easy fix, though.
Richard Beck
Ryan James
Shouldn't there be two aluminum spacers? Current list shows only one.
Ryan James
Ryan James
Nevermind. It would help if I read how many came in the package.
Ryan James
Jimmy Hardman
I cant download the STEP file. Cna you post as .zip?
Jimmy Hardman
Jonathan Wegener
Is the v-wheel kit out of stock? It's the only item not showing up as checked.
Jonathan Wegener
Kyle Eggerstedt
How much weight can this carriage support?
Kyle Eggerstedt
