Squatty Potty Phone Stand
31 opens
2 copies
Dustin Smith
Dustin Smith
This is a fun phone stand to help go hands-free while spending time with the Squatty Potty. The Squatty Potty acts as the base for the stand and requires adding a small .75" hole (square for stability). The stand is comprised of 3 upright poles and a top that all connect together.
#easelpowerhour
Walnut (×2)
6" × 12" × 3/4" Walnut
$22.86
$22.86
Acquire Squatty Potty or Stool
First, purchase a Squatty Potty or some sort of low stool. Make a square opening that is approximately 3/4" square (.75″ × .75″) in the top of the stool between where your feet will sit.
Cutting the Stand
Place your material on the CNC and get it positioned. Open Easel and begin the first cut on your first piece of 6″×12″×3/4" wood. Go ahead and cut. This first piece is the top of the phone stand.
Once the first piece is finished, repeat the steps using the second page and second piece of material. The second page has the pole that will thread through the Squatty Potty and will hold the top of the phone stand. Each pole is designed with a “T” style cutout so that they will fit together.
Assemble
3 minutes
When the cuts are finished, sand off any rough parts and then assemble. You can either glue the poles together, or leave them as-is so that the stand can be broken down and stored in smaller sections.
Once assembled, enjoy your hands-free experience!
Made one? Log in to add yours
