Square Challenge Coin Holder
0 opens
0 copies
413 downloads 0 comments
Jeremy Hill
Jeremy Hill
Basic square challenge coin holder made from cedar wood.
Details for two coin holders cut at the same time.docx
Details of build parameters
1st Layer
Within Easel:
1st Layer (file 11X11 Square Coin Holder)(https://www.inventables.com/projects/11×11-square-coin-holder) Details below for left most square coin holder. Files show two coin holders- remove the second one as needed.
-Set material dimensions (I used X=23.0625 in, Y=11.4735 in, Z=0.79 in)
-Cut settings 40 in/min, depth 0.0825”/pass (cedar)
-(outer edge(OE)) Click rectangle tab, set details in opened tab:
X=0.25
Y= 0
Width (W) =11”
Height (H) = 11”
Cut depth 0.79
-(outer box(OB))Click rectangle tab, set:
X=0.75
Y=0.50
W= 10
H = 10
Cut depth= 0.385
- (inner box(IB)) Click rectangle tab, set:
X=1.125
Y=0.8750
W=9.25
H= 9.25
Cut depth = 0
-Select the two (outer box, inner box) boxes using shift key and mouse, click ‘edit’ and ‘combine’ from pull down menu. (creates the 0.375” wide channel, 0.385” deep)
-Verify cut depth 0.385” on new object (combined box)
- Click “outer edge”, click ‘edit’ and ‘send to back’
- Click “combined box”, click ‘edit’ and ‘send to front’
2nd Layer
40 minutes
Layer 2: (file 9.25×9.25 Square Coin Holder) (https://www.inventables.com/projects/925×925-square-coin-holder)
This layer follows the same process as layer 1 with these changes:
(OE)
X= 0.25
Y=0.25
W= 9.25
H=9.25
Z=0.79
(OB)
X=0.75
Y=0.75
W=8.25
H=8.25
(IB)
X=1.125
Y=1.25
W=7.50
H=7.50
Layer 3
Layer 3 (file 7.5×7.5 Square Coin Holder) (https://www.inventables.com/projects/75×75-square-coin-holder)
(OE)
X= 0.25
Y=0.50
W= 7.5
H=7.5
Z=0.79
(OB)
X=0.75
Y=1.0
W=6.5
H=6.5
(IB)
X=1.125
Y=1.375
W=5.75
H=5.75
Layer 4
Layer 4 (file 5.75X5.75 Square Coin Holder) (https://www.inventables.com/projects/575×575-square-coin-holder)
(OE)
X= 0.25
Y=0.50
W= 5.75
H=5.75
Z=0.79
(OB)
X=0.75
Y=1.0
W=4.75
H=4.75
(IB)
X=1.125
Y=1.375
W=4
H=4
Layer 5
Layer 5 (file 4×4 Square Coin Holder) (https://www.inventables.com/projects/4×4-square-coin-holder)
(OE)
X= 0.25
Y=0.50
W= 4
H=4
Z=0.79
(OB)
X=0.75
Y=1.0
W=3
H=3
(IB)
X=1.125
Y=1.375
W=2.25
H=2.25
Layer 6
Layer 6 (file 2.25X2.25 Square Coin Holder) (https://www.inventables.com/projects/225×225-square-coin-holder)
(OE)
X= 0.25
Y=0.50
W= 2.25
H=2.25
Z=0.79
(OB)
X=0.75
Y=1.0
W=1.25
H=1.25
(IB)
X=1.125
Y=1.375
W=0.5
H=0.5
Sand all pieces
Sand each layer. I used an orbital sander to clean up the edges and faces of each layer.
Apply Polyurethane
I applied three layers of polyurethane on the coin holder
9
Add 9" lazy susan
Screw in 9” lazy susan to bottom of coin holder
(one example – http://www.amazon.com/Capacity-Bearing-Turntable-Bearings-VXB/dp/B0045DYHLQ/ref=sr_1_2?ie=UTF8&qid=1453334897&sr=8-2&keywords=9%22+lazy+susan)
