Spiral Drawing Toy
298 opens
126 copies
John McWhirter
John McWhirter from Inventables
Chicago, USA
A fun and educational tool for drawing spiral patterns.
Baltic Birch Plywood
8" × 12" × 1/8" Baltic Birch Plywood
Blue Expanded PVC Sheet
8" × 12" × 1/8" Blue Expanded PVC Sheet (Do not use)
Watch the Class
Make It Yours
Experiment with different hole shapes and patterns on the inner gear to make your own unique spiral art!
I’ve found that curved shapes work better than straight-sided ones. Asymmetric shapes can produce some cool effects—go nuts!
Carve It
16 minutes
I’ve tried it in both baltic birch plywood and expanded PVC and they both work. Acrylic would be ideal, but you would probably have to remove the tabs and use double-sided tape.
Share Your Work
Share your gear generator projects with the Inventables community in this forum post.
