She combines principles of electromagnetism, complex controls systems and the long know concept of time.
A sphere levitates in thin air, rotating about a light source. Tracking time, making reference to our beloved solar system. Mesmerising anyone brave enough to look.
More info: adorevolution.com
The author’s moral rights;
So, it looks like some part clock, some part orrery. How about a description to see what we are looking at? I don't see any moving parts that could put the "sun" into a different position. Intriguing and very nice looking.
hendrick.neil@gmail.com
Is the source code for this project available?
Ivan Vuletich
Hi Ivan, unfortunately the code is not available, but you can find a very similar concept here. http://zeltom.com/products/magneticlevitation hope it helps.
Sebastian Morales
Ivan Vuletich
Sebastian Morales
